Eyepiece Apparent Field of View
To get the actual field of view, divided the apparent field of view by the magnification.
For example, a 6" F5 scope (focal length is 150mm x 5 = 750mm) using this 4mm 82 degree AFoV eyepiece will give you:
magnification = scope focal length / eyepiece focal length = 750 / 4 = 188x
actual field of view = apparent field of view / magnification = 82 / 188 = 0.44 degree.
The "82 degree" mean that this eyepiece got an apparent field of view (AFoV) of the 82 degree.what does it mean " 82 degree "
Using the 6" F5 scope (focal length is 150mm x 5 = 750mm):
1) 4mm 82 degree eyepiece Actual FoV = 82 / (750 / 4) = 0.44 degree
2) 4mm 50 degree eyepiece Actual FoV = 50 / (750 / 4) = 0.27 degree
1) Kellner: around 50 degree,
2) SMA (Super Modified Achromat): around 40 degree to 52 degree
3) Plossl/Super Plossl: around 50 degree
Err... What do you mean?? Look the same, but just cover a smaller part of the sky lor. Anyway, the full Moon is around 0.5 degree, so 0.44 degree is slightly smaller than the full Moon. Please note that a large AFoV eyepiece will cover a larger actual field of view compare to a smaller AFoV eyepiece if both have the same focal length. For example:But how's it look like at 0.44 degree???
Some low cost, entry level eyepiece will not indicated the AFoV on the eyepiece. You can check whether it's indicate in the scope manual if the eyepiece come with the scope. Below are some of the AFoV for some common entry level eyepeiece type:Mine 4 mm eyepiece didnt state any AFoV??? why??
I create a simple example of the view through the eyepiece with same magnification, but different apparent field of view.
- Attachments
- Same magnification, but different apparent field of view
- Eyepiece AFoV View.jpg (71.06 KiB) Viewed 5322 times
