Need 300mm internal diameter tube for 10" DIY Newtonian
dragoncai2008
Post by dragoncai2008 »
Hi Buddies,
I am planning to DIY 254/1250 f5 newtonian telescope. I need to solve the tube!
sepc: internal diameter 280-300mm, length:1270mm.
anyone who knows the place to get such aluminium/alloy tube, pls leave your helpful information.
thank you.
Last edited by dragoncai2008 on Fri May 07, 2010 11:06 am, edited 1 time in total.
I presume size is the issue. There are these stores selling steel pipes of all shapes and sizes. Have never seen on that big though but still worth a try. There is one at the cluster of shops at the junction of Yio Chu Kang and AMK Avenue 3 along AMK Ave 3. You can try there.
kayheem
Post by kayheem »
You can also use sonotubes found here:
http://www.sonoco.com/sonoco/Products/Concrete_forms/
They are located near Pandan Reservoir area and they sell to end users.
10,000rpm
Post by 10,000rpm »
The man has spoken! :mryellow:
kayheem,
they sell to end users? the lady at sonoco told me they will only sell a minimum of 50meters!
kayheem
Post by kayheem »
Hmmm.... at least they did sell to end users the last time I went down.
You can use their drums and secure them end-to-end.
Your other options are to use PVC tubes. They may not be 100% straight, but I suppose they may be good enough. But, boy, they are heavy. Why not consider a truss design? Are you using it on a GEM?
I'm currently in the middle of a truss build :-P
Precisely because I cannot get tubes. I made a mistake and built everything oversize, a 14" mirror would probably fit (my mirror is 10"). All I'm missing is the trusses themselves (have the mirror box, rocker box, and UTA already built). Already did first light last week (using broom handles duct-taped as trusses!) [smilie=embarrassed2.gif]
10,000rpm
Post by 10,000rpm »
Haven't u gone to Teck Leong Alu?
kochu
Post by kochu »
Hi
Another practical way is to buy aluminium sheet and get the help of pipe fabricating workshops to bend it to the desired dia and join the butt by rivetting, or , still better by aluninium tack welding.
Kochu/7-5-10
10,000rpm
Post by 10,000rpm »
That's how the commercial Newtonian tubes are made... well at least for my Celestron and Orion ones.
