WTS: Losmandy G11 Mount + accessories (whole package!)
Hi all,
It comes as a difficult position to do this, but after some thought, I really have to sell the entire mount setup. There is no way the house can take two mounts at the same time. So here goes:
Losmandy G11 Mount package that includes:
1) G11 Mount Head
2) Solid tripod
3) Half Pier Extension
4) Customized-design wedge for equatorial latitude usage
5) Dual motors (RA & DEC)
6) Hand Controller
7) Mount CPU Drive System (492)
8) Assorted range of original Losmandy plates
9) DA accessories (i think i have two or three)
10) Losmandy tube rings (i think they are 125)
11) Tripod Oversized Knobs for ease of control
12) Electrical wiring adapters for 12V use
13) High precision worm installed.
14) Original worm supplied.
Basically, it is a migration to a different mount brand, so that's no point keeping anymore losmandy accessories. My loss, your gain. I have invested nearing SGD$7000 over on all the above. Yours for EVERYTHING above. SGD$3333. Lucky number?!
This is a time tested mount as everyone has seen. All the images on www.celestialportraits.com and on cloudynights taken by myself are captured using this mount. The autoguiding works fine with PHD, with MaxIMDL, CCDOops, CCDSoft, and likewise for most other software. You can mount almost anything with it (up to C14, visual). I have used a variety of OTAs with it from humble 3-inches to C11, it carries them with a charm.
Would appreciate if you could directly SMS/call me at 8 two 3 3 3 seven 9 eight, as I am unable to check PM in the day.
Photon Bucket
wah bro....what did you replace the G11 with?
starfield
Post by starfield »
pictures?
starfield: Please give me a moment. I will gather some pictures tonight.
vinsnr: may bring the new mount during a2008. it is midflight now. *hint* loading cap: 50lbs.
Photon Bucket
starfield
Post by starfield »
sphinx sxd??
Mach1
Here is a the G11 setup with the TOA. [err..scope and camera not included]
Photon Bucket
ariefm71 wrote:Mach1
Mach1 load is at 45lbs.....
Close enough I guess.
Losmandy Titan can take far more than 50 lbs and 900GTO is about 70lbs.
So could be Mach1.
Post by Meng Lee »
I guess Mach 1 GTO also!!
still no sale? Will consider instalments...
Photon Bucket
