Excellent condition almost as new.
Comes with carrying case, tripod, pier extension, zero latitude counterweight shaft adaptor and 4.5kg CW.
Specs:
Unique design, center-balanced equatorial mount (CEM)for maximum payload and minimum mount weight
Ideal for both visual observation and astrophotography
Low periodic error (< ± 12 arc seconds)
Payload of 12 kg (26 lbs) with the mount-only weight of 4.5 kg (10 lbs)
CNC machined and cast metal body
Spring loaded gear system
Large easy to use quick-lock gear clutches
0º latitude operation with optional adapter
Stepper motor with low power consumption
Integrated iOptron iPolarTM electronic polar scope
Polar alignment routine for those who can’t see the Pole Star
Go2Nova® 8409 controller with Advanced GOTONOVA® GOTO Technology
Integrated ST-4 autoguiding port
Built-in Wi-Fi
USB port for firmware upgrade and computer control
Standard 1.5 inch heavy-duty stainless steel tripod (5kg)
Die-cast metal tripod spreader with accessory tray
Asking just $800. Perfect entry-mid level astrophotography setup.
Whatsapp 9 six 3 nine 4711.
WTS iOptron CEM26
WTS iOptron CEM26
- Attachments
- cem26-2.jpg (582.16 KiB) Viewed 6861 times
