WTS : APM 152mm F/6 FCD-100 SD APO ***Strehl 0.984!!!
denis0007dl
Post by denis0007dl »
For sale my amazing APM 152mm F/6 FCD-100 SD APO with BIG 3.7" Rack&Pinion focusser with 360degrees rotation and micro adjustment!
Condition both optically and mechanically absolutely like NEW!
Lenses never touched!
Even Losmandy rail is like NEW without any marks on it!
Perfectly collimated!
Reason of selling is Im buying larger binoviewers friendly telescope!
Iti s binoviewers firendly for any binoviewer configuration, with plently of backfocus!
Its fast very portable doublet with one FCD-100 element + one secret additional ED glass, so its actually double ED telescope!
Colourcorrection at focus is excellent!
My item is hand selected and will have unusual superhigh Strehl 0.984!
Pictures it provide visually are really stunning, on both low and high powers!
Perfect instrument not only for visual, but also for demanding astrophotography (just please check online tomasz-trzcinski.info, go into his Menu, and check incredible images he did with same instrument).
Telescope visually show central star of the Ring with 400x magnification, under magnitude 7 sky!
Telescope setup weight is 10kg only with included rings and Losmandy style rail and frontcap, and tottal lenght when sheild is retracted in, 75cm only.
It originally usually comes/ships with carton box, and perforated very thin foam, but I will rather ship it carton boxes + additionally purchased soft case (for FREE) for much better protection + I will add a lot of air bubble foil around scope and soft case between boxes.
I will exclude only top handle which I took for some of my other telescopes, but its not even needed for that light and short telescope, and anyhow if you want buy it elsewhere, its cheap and available in many forms or you can made one custom made for yourself if you need it.
Full shop price of telescope is 4495 Euros + shipping.
My price for that hand selected item, with superhigh Strehl is 2450 Euros only + 120 Euros shipping anywhere worldwide.
Dont miss it, its ony one available at such superlow price, and superhight Strehl!
Kind regards and all best,
Denis, binoviewers expert
denis0007dl
Re: WTS : APM 152mm F/6 FCD-100 SD APO ***Strehl 0.984!!!
Telescope sold to Australia, thanxs to forum,
kind regards to all,
Denis
