what is the differences??
geraldine
Post by geraldine »
sm1 ca help me wif dis qn: wads d diffrnce btwn luminosity, magnitude and brightness of a star? tks alot!! :D
acc
Post by acc »
Geraldine, please post in proper English next time. Thanks.
Luminosity - are the amounts of energy that the Star radiate into space.
Magnitude - are the unit use for brightness in astronomy. There are a few type of magnitude, but the most common one are apparent or visual magnitude and absolute magnitude. Basically, the different in one magnitude is around 2.5 times. For example, magnitude 1 is around 2.5 times brighter than magnitude 2.
Brightness are shown in magnitude.
Hope the above answer your question. Have a nice day.
Sam Lee
Post by Sam Lee »
Where magnitude only tells us the brightness of the object 'optically', luminosity actually refers to the whole electromagnetic spectrum. Whatever the star is radiating, x-rays/ultraviolet rays, are all taken into consideration when we are talking about luminosity.
Eg. Star A might be optically brighter than Star B, but Star B has stronger x-rays emission than Star A. Therefore if we are talking about Magnitude, Star A is brighter. Case for Luminosity, Star B is 'brighter'. 8)
Sam
We are the Borg, Resistance is Futile.
cinq
Post by cinq »
Hi
According to the The Facts on File Dictionary of Astronomy.
Luminosity - The intrinsic or absolute brightness of a star or other celestial body equal to the total energy radiated per second from the body.
Magnitude - A measure of brightness of stars and other celestial objects.
Something quite useful is the "Apparent Magnitude". That's the magnitude as seen from earth if you're looking for objects for visual observation.
Cindy
When an amateur astronomer says 'magnitude', the person usually refers to 'apparent magnitude', which is a measure of the relative brightness of the stars or other celestial objects as seen from the earth. It is called 'apparrent' because, for example, star A may be actually (intrinsically) brighter but further than star B but from the earth both stars can appear to be of the same brightness. We then say both stars have the same apparent magnitude! So the apparent magnitude of a celestial object cannot tell us how bright that object actually is. Stargazers usually just say 'magnitude' for brevity and convenience.
Then there is this term call 'absolute magnitude' which is a measure of the intrinsic (actual) brightness of the object. It is define as the apparent magnitude a celestial object would appear if it is at a distance of 10 parsec (around 32 light years) from us.
Luminosity of a celestial object is a measure of the amount of energy radiated from the surface of that object every second. For stars, this depends on the surface temperature (which relates to the colour of stars) and size of the star, ie, bigger star radiates more energy than smaller star, assuming both are of the same surface temperature. Luminosity is directly related to absolute magnitude, but not apparent magnitude.
Kamikazer
Post by Kamikazer »
just in case anyone's wondering:
a parsec is the distance required of an object to produce a parallax shift of one arc-second...its aprox. 3.26 lys
K.L. Lee
ChaosKnight
Post by ChaosKnight »
Kamikazer wrote:just in case anyone's wondering:
I don't understand......please elaborate. Parallex shift of 1 arc sec as seen from where??
The definition i read a long time ago was "a distance of 1 AU subtended at an angle of 1 arc sec."
Check out the below website for the above question:
http://smaug.astr.cwru.edu/heather/221/parallax.html
oops...I should have explained in my earlier post...
One parsec is defined as the distance of a star (nearby) which has a PARallax (apparent shift in position against the background stars) of one arc SECond (hence PARSEC) when viewed from the Earth six months apart (ie, from the two extreme opposite positions of the Earth's orbit).
I hope this clarifies the above issue.
