diy adjustable-height pier
kingkong
Post by kingkong »
has anyone seen a design, or have any idea on how to build a adjustable height pier?
i've a pier built for newtonian which is painfully low for refractor and sct... so i'm getting itchy again... :oops:
river
Post by river »
possible to show a pic? See is it possible to design some adapter to put on your newtonian pier so that you can use it for all your scope.
or
http://www.pwtec.com/pinnacle.htm
kingkong
Post by kingkong »
interesting. it's not clear how the center column is secured... is it continuously adjustable by friction..? or more likely, locked in place by bolts/pins.
i find the 1000lb load test photo gimmicky. that ability to hold a vertical static load doesn't say anything about sway, vibration damping, etc.
a simple solution i have is to add a 1'-2' I-beam below the current pier to raise its height and use step stool for higher ep/focuser position, risking mis-stepping and falling in the dark...
for that kind of prices, might as well buy a pier-tech push-button electro-mechanical adjustable pier...
http://www.pier-tech.com/store/agora.cg ... Pier-Tech2
river
Post by river »
yup very $$, but that give you some idea how to adjust the height. There is a level on one of the three rod, I think that's how the user will secure the pier.
Probably as you only need two heights for your refractor and newtonian, I think it is cheaper and easier to just make and add on a half pier extension.
kingkong
Post by kingkong »
good suggestion rlow. any one got lobang for good cheap half-pier extension? will need one of 12" vixen/meade type. i got one made in kl, can use but not very good...
