I was testing my Canon EF 50mm f/1.8 II prime lens for wide field astrophotography on last monday 3 Jul 2006 at the multi-storey carpark near my block. I hope I can find the best fastest f-stop for this camera len. I took a 60s (at ISO 800) shot at every f-stop from f/1.8 to f/6.3. A LPR filter was mount on the Lens to reduce the light pollution.
As I was examine the images, I find that I can see some part of milky way on the images. I decided to process and stack the images (12 images at different f-stop ) and see what can I get. I setup the camera and lens to take the flat field and dark frame... supposed to took during the imaging session, but I guess it better than none...
To my surprise, the image looks quite good... Hmm... I think we don't need very dark sky to take decent wide field astrophotograph after all and it is possible to do that in Singapore.
By the way, the fastest f-stop that will produce a decent star image for the Canon EF 50mm F1.8 II prime lens is at f/4... err... at least for my standard.
I must say I'm surprised myself! Well done! Is there somewhere we can get the full resolution image?
I attach a zip file which contain a full resolution medium quality jpeg file... for those who interested to take a look... it look quite ugly at full resolution... I didn't perform a lots of processing on it... too lazy...
Can you post a picture of what the 2" LPR with the step-down ring on the lens looks like? I'm curious to see..
Ok. No problem.
Hmm.. any reason why you use the UV Skylight filter together with the LPR? Might that not cause additional reflections on bright objects?
Just wondering...
