hi...new in here...hope i can get some help here....
1) May i know how much is a PowerSeeker 60 (which i view it at http://www.astro.com.sg)? and is it good enough for a newbie?
2) I have seen some topic and ur do recommand 5" for newbie....eerrr...may i know what does the 5" means? the size of the lense?
3) Reflector and Refractor...which is better? i only know that the Refractor have a mirror inside which need to be clean where i have seen it in one of the topic...
4) i have read one of the topic and it stats that diff Focal length let you see diff stuff...then how do you know which is which? like f/8, f/11, f/12, f/15 ect....
price of telescope
As I had mention, read the FAQ ( http://www.singastro.org/viewtopic.php?t=32 ) first and it'll give you some idea of what telescope is and what to look for... then post here if got any more questions.
By the way, welcome to SingAstro!!!
PS: Some formula for your quick reference:
f-ratio = focal length of telescope / aperture of telescope
magnification = focal length of telescope / focal length of eyepiece
Field of view = apparent view of field of eyepiece / magnification
My recommendation is don't get the PowerSeeker 60 (a 60mm scope) as a first scope. The 5" here mean the aperture of the telescope is 5" or 127mm... the diameter of the pimary mirror or lens. My recommendation for first scope is at least a 4" or 102mm for refractor and at least 5" or 127mm for SCT/MCT/Newtonian.1) May i know how much is a PowerSeeker 60 (which i view it at http://www.astro.com.sg)? and is it good enough for a newbie?
Refractor got no mirror... it use lens only. Reflector use mirror and Compound scope (SCT/MCT) use both a corrector plate (a type of lens) and a mirror. It got quite a numbers of factor when deciding between which type is better... usually price, quality and portability. Read the telescope faq in the faq section.3) Reflector and Refractor...which is better? i only know that the Refractor have a mirror inside which need to be clean where i have seen it in one of the topic...
The f/12, f/15 & etc is what is called f-ratio. A "faster" scope (smaller f-ratio, such as f/5) mean it can see a wider field of view more easily than a "slower" (bigger f-ratio, such as f/12) scope of the same aperture. So if you are interested in viewing wide field, usually you'll selected a "faster" scope, but if you are more interested in planetary, double star or those require high magnification, then a "slower" scope may be more suitable.4) i have read one of the topic and it stats that diff Focal length let you see diff stuff...then how do you know which is which? like f/8, f/11, f/12, f/15 ect....
Welcome!
By the way, the way I learnt about telescopes is to read the catalogs! Heh.. Lucky you, there are lots of online catalogs available... but don't believe everything it says!!
Cheers!
Cheers!
- Canopus Lim
Personally, I would recommend binoculars to newbies only if they have a low budget of $100-200. If they can afford it, I would recommend a 5" SCT or MCT on a portable mount e.g. Manfrotto 410 gear head with Manfrotto 055 tripod or equivalent.
This is a deadly combo of aperture, portability and simplicity. It has enough focal length for a pleasing view of planets and a decent aperture for DSOs. It can also be set up in 1 min.
What still applies is that the person should still look around, try out the different scope types before deciding.
- Canopus Lim
- Canopus Lim
