Homemade TMB 80
anat
Homemade TMB 80
Post by anat »
I have just finished my another project... Homemade TMB 80. I use the original OTA from Vixen A80SS (about US$150 in Japan excluding red-dot finder and flip-mirror). It is as short as 11 inch.
anat
Post by anat »
When looking through the scope, stars are not as white as the tube color. :) So, I wanted to change the lens. The following photo shows the scope with the lens cell removed.
anat
Post by anat »
Fortunately, I got a new TMB 80/480 lens cell from an Astromart auction. The lens cell has a M85x1 thread.
anat
Post by anat »
I needed to make an adapter to couple the TMB lens cell to the Vixen tube. So, I took a close look at the Vixen lens cell. The Vixen lens cell has an inside diameter of 80 mm and an outside diameter of 90 mm.
anat
Post by anat »
So, I decided to use the Vixen lens cell as the adapter for coupling the TMB lens cell to the Vixen tube.
anat
Post by anat »
The following photo shows the lens cell with lenses removed. I used the part on the left.
anat
Post by anat »
The next step is to make a M85x1 female thread in the Vixen lens cell. One of my friends kindly did it for me. It is the most critical part of this project because I need to make sure that the lens cell axis coincides with the thread axis in order to prevent miscollimation.
anat
Post by anat »
Then, the Vixen A80SS tube was coupled to the TMB 80 lens cell. The length of the shortened tube is 13 inch. Note that the TMB lens cell comes with a TMB logo as seen at the tube side.
nice effort anat...
I could never do that although I had tertiary training...! :-)
anat
Post by anat »
This photo concludes my post. I would like to thank Liu Ming for valuable suggestions and for making me have more confidence to finish this project. This project costs about US$800 :) :) BTW, the microstar mount is from KingKong and the diagonal is from rlow :)
Anat
