Jupiter & saturn
AGMI
Jupiter & saturn
Post by AGMI »
this is my first time photographing them without using hand (ok lah i jus tape the cam to the eyepiece...5mm plossl..) pls tell me how i can improve..thks
i think you have done a good job, Allan. You can further improve of this by stacking multiple frames. Most planetary images would stack sometimes up to 700 frames within a short period to enhance the signal to noise ratio. Have you downloaded Registax version 2? It is a great freeware for this sort of thing. I have just purchased the Toucam II for planetary imaging, and hope to spend some time dwelling in this form of imaging.
Good luck!
AGMI
Post by AGMI »
stacked already...just that i forgot to fine focus :k-_-:
chrisyeo
Post by chrisyeo »
It's a good first effort!
Does your camera have a video mode? You might want to use the video mode to capture images.
For focusing, you can set your camera to infinity, then what I do is I use a clothes peg on my focuser to do fine adjusting. Works like a charm.
AGMI
Post by AGMI »
uhh my mount no tracking so quite hard to track.....
