Used Celestron Nexstar 8 GPS Telescope and a bit of a rare find. Celestron built the Nexstar GPS telescopes before the current CPC models. These were made in the USA and are Fastar compatible plus they have the Carbon Fiber optical tubes. All this makes them a very desirable telescope.
General Weight 41.89 lbs Manufacturer Celestron Optical System Telescope Class Schmidt-Cassegrain catadioptrics Max Magnification 480 Telescope Aperture 203 mm Focal Ratio f/10 Resolving Power 0.68 arc sec Lens Coating Starbright Limiting Visual Magnitude 14 Telescope Features 16-channel GPS receiver, AutoGuider port, Auxiliary port, diagonal mirror Telescope Focal Length 2032 mm Eyepieces Barrel Diameter 1.25" Included Qty 1 Focal Length 40mm Finderscope Type Finderscope 9 x Objective Lens Diameter 50 mm Type finderscope Magnification 9 Telescope Mount Type altazimuth Motor Drive System dec.(declination), r.a.(right ascension) Slew Speeds 0.5x sidereal, 16x sidereal, 1x sidereal, 4x sidereal, 64x sidereal, 8x sidereal Electronic Control System GoTo Electronic Control System Memory 40000 celestial objects Tripod Type Tripod Type tripod Manufacturer Warranty Service & Support 2 years warranty Header Brand Celestron Product Line Celestron NexStar GPS Series Model 8 GPS Optical System Details Magnification 51 View Angle 0.91 degrees Eyepiece Focal Length 40 mm Dimensions & Weight Weight 41.89 lbs Length 1.7 ft
Reason for sale is to fund my mum medical expense n am not in the hobby anymore.
will pass all the accessory that i have with regard to astronomy.
The other thing to look out for is that this telescope lens is covered in mould.
Buyers need to be able to clean it up properly b4 use...
No tripod pls take note.
Looking to sell at 2k.or ur offer..
Thank you.
WTS : Used Celestron Nexstar 8 GPS for sale
- Attachments
- 416692XDA9L.jpg (24.73 KiB) Viewed 2432 times
- Favourite scope: Orion ED80T CF
Re: WTS : Used Celestron Nexstar 8 GPS for sale
You still selling?
Sent from my CLT-L29 using Tapatalk
