Hi guys, how do you "transform" a eq mount to an altazimuth mount? I have a little problem using eq mount navigating the skies due to its unability to polar align. All help will be appreciated
Clear skies
Sent from my GT-S7275R using Tapatalk
Eq mount
- Favourite scope: Sky-Watcher SkyMax 90mm, Coronado PST
Re: Eq mount
Hello,
You cannot "transform" an EQ mount to an AZ mount, unless you are specifically referring to the Sky-Watcher AZ-EQ5 mount.
Thanks.
- Favourite scope: maksutov
- orly_andico
Re: Eq mount
the old Vixen Polaris can also be transformed into an alt-az mount.
http://www.astromart.com/reviews/articl ... cle_id=465
- Favourite scope: Orion 127 Mak on a Skyview Pro EQ mount
Re: Eq mount
[quote="orly_andico"]the old Vixen Polaris can also be transformed into an alt-az mount.
Any equatorial can be "turned" into an altaz mount. In SG just adjust polar alignment 0 degrees and you have an altaz mount
