Collimating the Celestron 127EQ Newtonian
haejae
Favourite scope: astromaster 130eq:p
Post by haejae »
My Celestron 127eq seems to be out of collimation but it does no have collimation screws on the back and no collimation cap. Can anyone help? [smilie=ahaaah.gif]
Great Red Spot
Favourite scope: Newtonian
Re: Collimation of 127eq
Post by Great Red Spot »
When the haze finally disappears, point to a star. Defocus the image. U will see a black shadow in the middle,like a donut. Make sure the donut is symmetrical.
haejae
Post by haejae »
Okay thank you. Is it feasible to buy a collimation cap?
Hi Haejae
There should be screws behind the mirror for this. Do check out the instruction manual which should provide the steps on how to do this.
Regards
antares2063
Favourite scope: Newtonians
Post by antares2063 »
Hi, if I remember correctly Celestron newt have a base plate covering the access to the collimation screws (at least mine did, but mine was a late 1990s design).
If the rear end of your scope tube has 3 screws, remove them and the thin "base" plate which will allow you to see the screws. If you already see 6 screws arranged in sets of 2 spread out like a triangle.. those are your collimating screws. (3x2)
You can trying searching on google or youtube for videos on collimation of the C127.
Regards
Junwei
Mibmom
Favourite scope: Celestron Nexstar 6SE
Post by Mibmom »
Hi there.
This is my Celestron 127eq for reference.
has 3 screws to adjust the Primary mirror.
C127eq back.jpg (24.39 KiB) Viewed 15107 times
Front has 3 screws for the Secondary mirror
C127eq front.jpg (18.78 KiB) Viewed 15107 times
I used a Laser Collimator I got from Aliexpress.
Regards
Take me out to the black
Tell them I ain't comin' back
Burn the land and boil the sea
You can't take the sky from me
~ Serenity
haejae
Post by haejae »
yes that it is MibMom
haejae
Post by haejae »
Which are the screws to adjust the primary mirror?
SebastianTai
Favourite scope: Officina Stellare Pro RC 800
Location: 137, Jalan Pahang, Setapak, Kuala Lumpur 53000 Malaysia
Post by SebastianTai »
Collimation will be not be possible using laser collimator. This is a Bird-Jones newtonian with corrector lens. The only best way based on my experience will be using star test to get a good collimation. Laser never get collimation done (Laser point become a large blurred circle due to presence of corrector lens)
