Planisphere
Planisphere
Hmmm...... I noticed tat most planisphere programs do not cater for equatorial region, they only have 30 degree north and above, but why? :idea: :roll: Is there any particular reason for tis?
Can a 30 degree planisphere be used for Singapore. :idea:
One simple reason: Small market. Most country that are very active in Astronomy, such as US, UK, Japan, China & etc, did not locate near equator.Hmmm...... I noticed tat most planisphere programs do not cater for equatorial region, they only have 30 degree north and above, but why? Is there any particular reason for tis?
Should be able to use, but it is very difficult to use and some part of the sky is not shown and you need to manually offset the constellation position.Can a 30 degree planisphere be used for Singapore.
Re: Planisphere
Like what weixing said..small market. The lowest planisphere I have seen is 20 degrees.fizzy123 wrote:Hmmm...... I noticed tat most planisphere programs do not cater for equatorial region, they only have 30 degree north and above, but why? :idea: :roll: Is there any particular reason for tis?Can a 30 degree planisphere be used for Singapore. :idea:
Use software la....
Physical space sells local planispheres.. www.tpspace.com
Thanks for the link, hlyf.
I didn't even know Wee Kiong had a website!....
Perhaps he should add it to his signature? And yes, I do recall him selling some planispheres in the past now that you mentioned it.
Most planispheres don't have DSO on it. Can you imagine what will happen to Virgo/Coma Berenices/Leo constellation if you just put the M objects in that region in the planispheres??? You can't see anything else... Ha Ha HaThose published by the Science center is really too basic and do not show bright DSO on it.
I saw his prototype planispheres for singapore use... quite nice. Just wonder when will it be ready???mm...i thought Albert from the Science Centre has instructions to make one in one of his books?
