I'll be fine in winter and at night. I have a drawer full of PC cooling fans I can install all over the inside of the suit if I need to.Airconvent wrote:Nice try-out Barry! But it looks like you may need some sort of cooling system inside the suit to avoid overheating!
Bazza's Iron-Man suit build
Re: Bazza's Iron-Man suit build
Builds By Baz
https://www.buildsbybaz.com
A short video of walking in the full suit.
Builds By Baz
I've been so strapped for time lately. This non-daylight savings is pissing me off. Stuff-all done on the suit in a while.
Today I made a start (only had 20 minutes). Reinforced the knee pivots with some heavy pipe welded in, some M10 cuphead bolts and washers in between the layers to smooth out the pivot. They move silently now.
Hopefully tomorrow I can weld a couple of struts into each side of the boots, to push the leg up high and enable the weight of the leg to rest on the ground, rather than hang on the suit.
Builds By Baz
Leg on the right now supported on a steel strut either side of the boot and pivoting at the ankle. The weight of the entire leg now sits on the ground instead of hanging off the suits torso. The gap between the top of the leg and the cod-piece is now a lot smaller and realistic looking.
Won't be scratching up the hospital floors now! Glueing on rubber soles.
Builds By Baz
Both legs have now been elevated and supported on pairs of solid steel struts welded to the boots and pivoting at the ankle. You can see an aluminium flat disk on the right boot - this will be replaced later with a more attractive steel turned toe-pivot. The flight control flap at the back of the ankle has been hinges so now it swings up as the boot and leg moves. The knee pivots will eventually be welded closed with an attractive cap once I'm happy I don't need to take the legs apart again. Rubber soles have been glued onto the bottom of the boots to save flooring.
The rib features have now been filled in from behind with scratch-built steel caps. It looks untidy with the positioning spot welds from the front and the rest of the welding from behind, but this will all be cleaned up later.
The steel sheet is only .95mm thick, so to give the illusion that it is thick armoured plate I have welded in some 8mm edging all around. Welding from behind except in spots I couldn't get the welding gun into. Edges will be cleaned up last.
The lighting is great, but the eyes are too bright for indoors and night. They overpower the dark so much you can't see the face, so I'll be adding a resistor/dimmer so I can vary the brightness as needed.
Builds By Baz
G'day my loyal minions. Here's an update for you.
My wonderful wife helped me get the legs and boots on for a test walk in the modified joints.
Now the legs are supported on steel struts welded to the boots and pivoting at the ankles. The knees have been silenced with washers in between the joints and the flight control flaps at the ankle have been hinged. They will be spring-loaded at a later date. The boots now have rubber soles to protect the floor.
Here's video and some photos.
Builds By Baz
Cool Barry!
Thanks mate!Airconvent wrote:Cool Barry!
![admire2 [smilie=admire2.gif]](./images/smilies/admire2.gif)
Builds By Baz
So, I've designed some little steel features to add to the suit to make it look more tech and set it apart from so many other suits that leave out detail and therefore look plain. I have a machinist doing it for me because it wouldn't be appropriate for me to use the lathe at work at the moment.
This guy is way better than me anyway.
I gave him simple drawings with a few guidelines only.
He's just dropped off all bar two pieces. (I have to get him some more steel). They look brilliant. Toe pivots, knee joints, elbows, shoulders front and back.
Builds By Baz
I'm still hopping along on a crook foot, (nearly broke it) but I brought an office chair on wheels into the workshop after work today and got a bit of welding done around the table. One foot on the ground, the other knee on the chair. It works.
Started with an arm and shoulder, welding on the new component detailed features.
Builds By Baz
