Actually, the light grathering power of a scope is not rated to f-ratio at all - the aperture is the main factor.
When people said that f/5 give brighter image than f/10... that is just a misconcept. I think most people got this idea is because of camera lens. Below is the formula for f-ratio:
F-Ratio=(Focal Length of Len) / (Diameter of Len)
It is true in camera len that a "fast" lens will generate a brighter image than a "slow" lens - how?? In camera lens, the f-ratio is control by the aperture: the smaller the aperture, the "slower" the lens; the bigger the aperture, the "faster" the lens. Remember, a scope aperture is fix. Then you will ask: How come I need to exposure longer using a "slower" scope than a "faster" scope in astrophotography?? This is only true if you use prime astrophotography(no eyepiece). Before I explain this, remember this:
As Magnification Increase, Brightness Decrease.
So, when you doing prime astrophotography, actually there is some magnification even you don't use eyepiece. In camera lens, 50mm is consider as 1x, so a 1500mm focal length scope is actually having a (1500/50) 30x magnification when use without eyepiece. So a "faster" scope with a shorter focal length will generate a brighter image, since it has a lower magnification, eg. 500mm focal length telescope - 500/50=10x.
Also, a "faster" scope will normally give a brighter and wider Field of View than a "slower" scope - why? This is because a scope with longer focal length("slower" scope) will normally give a higher magnification, so dimmer image and narrower Field of View, than a scope with shorter focal length("faster" scope) when using the
SAME EYEPIECE. To show my point, below is a comparsion between a "fast" scope and a "slow" scope (both will have same light gathering power) using a
40mm eyepiece with Apperant Field of View(AFoV) of 43 degree:
102mm (4") f/5 telescope
Aperture: 102mm
Focal Length: 510mm
Magnification: 510/40=12.75x
True Field of View (TFoV): 43/12.75=3.37degree
102mm (4") f/10 telescope
Aperture: 102mm
Focal Length: 1000mm
Magnification:1000/40=25x
True Field of View (TFoV): 43/25=1.75degree
My english is not very good..
Hope the above explaination is clear enough and you get my point...
Have a nice day...
