hmm... not sure why this is so. Can anybody explain?a parabolic shape doesn't introduce coma, making the mirror too fast introduce the coma. if one were to make a 8" f/10 parabolic mirror, no coma would be visible.
But i thought that's only in the centre of the FOV. There would still be coma at the edges. As quoted from http://www.opticalmechanics.com/about_coma.htm,
Also, can anybody explain how a coma corrector works?The surface of a Newtonian telescope’s primary mirror is parabolic. The parabola is the only geometric Surface that will focus a bundle of parallel rays to a point. Except for the limitations due to diffraction and atmospheric turbulence (seeing), a perfect parabola would focus a bundle of parallel rays to an infinitely small point. However, this is only true if that bundle of rays is parallel to the axis of the parabola or parallel to the optical axis of the telescope. When you center a star in the fov of a telescope the above condition is met and there is no coma in the image.
When a bundle of parallel rays from a star strikes the parabolic mirror at an angle, the star image is formed off the optical axis, or decentered in the fov. The parabola does not reflect this bundle of angled rays to a perfect point. Instead, the star appears as a bright spot with a V-shaped comatic flare.
My third question is this: Since good parabolic mirrors produce excellent images, why do SCTs and MCTs have undercorrected mirrors with correcting plates instead of parabolic mirrors with no correcting plates? Has it got to do with the f-ratio of the SCTs and MCTs?
4:The f-ratios of SCTs and MCTs confuse me. It's stated that the Fastar Lens assembly for prime focus CCD imaging allow the telescopes to be optimised for a ratio of f/2. Also, a focal reducer lens reduces the f/ratio to f/6.3. But for visual observing, f/10 configuration is used instead. How come the f-ratio can change so dramatically?
5:still not sure what mirror shift in SCTs and MCTs is caused by.(moving of the primary mirror?)There's this crayford focuser which solves the problem of mirror shift, how does it work?
Only a sec 4 student, so dont know much:( Thanks for any answers.
