Can you manually set GPS coordinates on a Nextstar 6se ?
Re: Can you manually set GPS coordinates on a Nextstar 6se ?
Just out of curiosity, is the firmware the latest version? You can connect it to the internet to update to the latest version + new objects. At least from the SE series onwards.
- dleger
- Favourite scope: Nexstar 6se + Canon EOS 60D
I'll have to check whether lastest firmware is installed or not...
The probem is tht you need to flash your handset usng the serial, I think, and I don't have a laptop with a serial port.... I guss I'll have to hunting for a USB-Serial adapter cable...
...Which isn't a bad thing, because then you can control the scope from you computer, as well as my Canon exposure control software... ;-)
Thanks,
Thanks,
--Dave--
