hi all
I need to take a variety of moon shots for a study project.
I have been using Registax before but here is my challenge: the moon is larger than the entire FOV of a Toucam on a 900mm f/11 refractor.. also I did not use the motor drive on my EQ-1 (too much trouble, no clutch on the motor) so the image floats across the FOV.
What I would like to do is stack + mosaic, so that I can use all the frames from my AVI. I don't think Registax can do this. Any suggestions?
(and "buy a Sphinx" or "buy a GP-D" is not an option at this time)
automatic mosaic-ing / drizzling software?
- orly_andico
- orly_andico
Hmmm... I feel a bit idiotic.
After spending the past couple hours Registax'ing and mosaic'ing moon images by hand, I figured out that the Toucam has a 5.6um pixel pitch, while my Pentax K20D has a 4.9um pixel pitch.
So for lunar images it seems I can just take single shots with the DSLR, get the whole moon in the frame, and not have to suffer through stacking and mosaic-ing.
Of course I can barlow the Toucam but probably cannot with the DSLR... (or will a teleconverter work... hmmmm.....)
I think newbies should know this technical reason why some people go for webcam shots and why some people go for DSLR shots.
(Good) Webcams can take shots at 30 fps or faster to capture a series of shots that consists of sharp and atmospheric-blurred pics. We then stack the sharp ones. This is for resolution.
DSLR shots are nice and they contain the most of the moon and stuff, but you can't record shoots this fast. You lose on resolution.
So you choose what you want.
Photo Album:
- orly_andico
hi all,
I know it's the sensor size. thing is, the pixel pitch is important to me because pixel pitch determines minimum angular resolution (per pixel) -- the bigger the pixels, the lower the minimum angular resolution at a given FL.
if the FL is long and aperture is big, the Toucam will beat the DSLR hands down because it can "beat the seeing." but I'm using a short (f/6.2) small (70mm) scope, for which the Dawes limit is 1.5 arc-sec. Since the pixel pitch of both the Toucam and DSLR gives ~ 2.5 arc-sec resolution at my FL, then the Toucam doesn't massively beat the DSLR for resolution.
Off Topic :
Oooh..Pentax K20D! Pentax is very famous here too...those delicious eyepieces that rlow and elton have!
Anyway, do join in the Pentax sub-forum at www.clubsnap.org , the biggest photographic online community in Singapore.
Have you tried the K20D on Orion yet? personally I think the K-x is more suited for this application because its images noise level are so good even Nikon and Canon are noticing.
- orly_andico
hi Airconvent
Yup I trawl CS just to look at the for-sale items :-D
pentax lens prices have been going up steadily these past months.....
agree on the pentax XW and friends.. too rich for me though!
I have not had any time to try the K20D.... maybe will get my wife a K-x which i can scam for DSO imaging :-D
