Astrophotography from a roof terrace
bernardchew
Post by bernardchew »
My second attempt at astrophotography from our Bortle 9 skies. Nothing fancy, just UV/IR filter with uncooled zwo585mc camera, sharpstar 61edph iii w reducer/flattener (FL 268mm, F3.9), iOptron cem26 (unguided). All without darks, flats etc, unprocessed other than live-stack using asiair mini.
Omega Centauri https://photos.app.goo.gl/zs9G3zjPBpoAGpW46 (10 secs x 30)
Centaurus-A https://photos.app.goo.gl/8dfMDPfHf4hCNDAG7 (30 secs x 30)
Markarian Chain (virgo supercluster) https://photos.app.goo.gl/1PA1cVRRkXBxKycu9 (30 secs x 40)
Sombrero Galaxy M104 https://photos.app.goo.gl/qEU93LFz8mbC1btcA (30 secs x 40)
Whirlpool Galaxy M51 https://photos.app.goo.gl/QXy6JeqAQDoboV4a7 (30 secs x 60)
Southern Pinwheel Galaxy M83 https://photos.app.goo.gl/5YzVZAYCq5fxRifK6 (30 secs x 40)
Eta Carina Nebula NGC 3372 https://photos.app.goo.gl/qDbtQMAWZMGo2w5TA (30 secs x 40)
Quite happy with what can be seen/captured through a small scope with modest effort (I’m lazy :mryellow:)
Bernard
PETER LOO
Re: Astrophotography from a roof terrace
Post by PETER LOO »
Bernard, very nice images, awesome and motivational
cytan299
Post by cytan299 »
Hi Bernard,
Very nice images. I'd actually venture to guess that it's really Bortle 7 to 8 at you location rather than Bortle 9 from your images. I'd suggest that you start stacking more than 30 subs (1 hour at 30 s is 120 images, 3 hours is 360 images) and then process offline. Looking at your data, I think it's possible to get pretty good broadband results.
I'm glad that imaging for more than 3 hours a session is possible.
Thanks!
cytan
PETER LOO
Post by PETER LOO »
It is quite intuitive to practicing imagers that Bortle class do vary over our small island. (Refer rifleman175's A Method of Determining the Bortle Class at my Observation Site), i do agree with rifleman's finding that "the light pollution at Senkang is around Bortle 7.0 at altitude of 55 degrees looking South". So, there is nothing to guess but for simplicity, we just say Bortle class 9 sky to represent SG in general.
bernardchew
cytan299 wrote: Fri May 03, 2024 7:31 pm Hi Bernard,
Thanks!
cytan
Thanks for the tip. Next round I will try to focus on just 1 or 2 objects with more subs for each of them :)
I was pretty much a visual observer all these years, so past few sessions have been sort of trial and error to see how many objects can be captured in a short observing session, ie more EAA rather than true astrophotography. Actually I’m quite blown away that with such a small scope, some of the dimmer objects can actually show up with details after just a few stacks. Other than Omega Centauri, most were just tiny grey smudges visually even with 6” or 8” scopes.
bernardchew
PETER LOO wrote: Fri May 03, 2024 8:46 pm It is quite intuitive to practicing imagers that Bortle class do vary over our small island. (Refer rifleman175's A Method of Determining the Bortle Class at my Observation Site), i do agree with rifleman's finding that "the light pollution at Senkang is around Bortle 7.0 at altitude of 55 degrees looking South". So, there is nothing to guess but for simplicity, we just say Bortle class 9 sky to represent SG in general.
You’re right that I sort of took it as a given that SG skies are Bortle 9 throughout the island as most of the time, only the brightest stars and planets are visible. Especially at street level, which was where I’ve been observing until recently. I never thought that astrophotography is possible in SG, until I saw some of the videos on youtube by “Cuiv the Lazy Geek”, who images from equally light polluted Tokyo. So I thought why not just give it a try?
bernardchew
Images of M51 and M57 taken on Thursday 9 May 2024 through Williams Optics Megrez II 80mm. Unguided subs using Zwo Asi533MC Pro cooled at 0degC. Streaks on M51 image likely due to live stacking. I did not take darks or flats.
M51: 60s x 50 live-stack, stretched using GIMP.
M57: 30s x 20 live-stack, stretched using GIMP.
Omega Centauri: 180s single-shot, no post-processing.
cytan299
Post by cytan299 »
Hi Bernard,
Your images look promising for more processing. I’d suggest that you do colour balancing in GIMP to get rid of the green. It’ll look a lot better after you do this.
cytan
bernardchew
Thanks for the tip. Yeah, I think I also overstretched some areas like core of M51.
I gotta learn how to properly use these image processing software first. Previously I just do visual and simple EAA with no post processing. Life was much simpler then :). But astrophotography can be addictive! (And costly $$$ :()
Saturday was first try with GIMP and last night finally figured out how to use Siril to do image stacking without darks and flats. Next will be to learn how to take flats and bias frames, plus do the auto guiding thing 😅.
PETER LOO
Post by PETER LOO »
Well done Bernard, 3 mins un- guided at mid focal length is remarkable.
