Need to make space for new toys.
2. IOptron SmartEq Pro mount: $250 (was $300)
Ok for goto and tracking with small (< 4kg) loads, eg 3” refractor or camera with 200mm telephoto lens, once properly aligned.
[img]https://www.dropbox.com/scl/fi/aktjzqg3 ... sz9vm&dl=0[/img]
[img]https://www.dropbox.com/scl/fi/laysaord ... 7kf6w&dl=0[/img]
5. IOptron SkyTracker (includes IOptron ball and socket mount head for camera): $150 (was $180).
Works ok for doing wide-field astrophotos with < 100mm lenses, depending on how well one aligns
the tracker to celestial pole (1-2 minutes unguided is not difficult with 50mm FL lens).
[img]https://www.dropbox.com/scl/fi/1tnaarcl ... s7b4v&dl=0[/img]
PM or WhatsApp me at 9 zero 12 six five 01 if interested.
Photos will be uploaded later.
Bernard.
WTS: Various Telescopes, Mounts and Accessories - Prices reduced for remaining items
Re: WTS: Various Telescopes, Mounts and Accessories
Hi Bernard
Pls reserve item 3 and 4...the borg 76 and the 100mm for me.
Upon receiving confirmation of reservation....pls pm phone number and will call you for setup at mrt station for deal.
Thanks.
Thanks.
Ok, as spoken, will amend the post shortly to indicate items 3 and 4 as reserved.
Cheers.
Cheers.
Hi Bernard
In case l forget to tell you.....
Pls note that.....if you have the various caps to cover the various parts /tubes when the borg scope is taken apart, pls give it to me so that l don't have to go to various places to source the cover. Frankly it takes months to search for cover of the appropriate diameter. Thanks.
Re: WTS: Updated to show remaining items - Various Telescopes, Mounts and Accessories
Prices reduced for remaining items.
