Hi All,
The Pentax K30 with O-GPS 1 Unit.
More About the Pentax Astrotracer and how it works.
All you need to do, Calibrate, Mount Cam, settings, point and start shooting.
The O-GPS 1 Unit locks on in less then 5 mins.
for the whole night only one Calibration is needed if you are not moving the Tripod.
Do note that as the system is not on a EQ mount,
you would need to track the object after every shot but not during.
Unit still trackes well at 450mm FL for 30 sec.
From testing, i notice that it tracks better when objects is higher up (say about 45-60 degrees)
Small and light upset for Widefield Astrophotograhphy on the go!
A few test shots in Malaysia:
MilkyWay Wide (Tamron 17-55 F2.8 suffers from coma @ 17mm)
7x3mins at 26mm @ F5.6.
4 Dark and 9 Bias
ISO: 3200
4 Dark and 9 Bias
ISO: 3200
M8 and M20 (Sigma 70-300 DG OS) (was not done well)
40 x 30 Sec at nearly 350mm @ F5.6.
10 Dark and 9 bias
ISO: 3200
M17 and M24 (Sigma 70-300 DG OS)
20 x 45 Sec at nearly 200-300mm @ F5.6.
7 Dark and 9 bias
ISO: 3200
For more photos from the Pentax K30 and their original Res you can visit my Flicker Page set:
http://www.flickr.com/photos/21190487@N ... 000822179/
Dave Ng
A light weight AP setup (Pentax K30 with O-GPS1 Astrotracer)
Re: A light weight AP setup (Pentax K30 with O-GPS1 Astrotra
Thanks for sharing! A very fruitful new moon weekend.
Thanks Gary!
yes indeed it was a very fruitful weekend!
Hope to share more photo soon during the next New moon!
