Ioptron ZEQ25GT mount?
PETER LOO
Re: Ioptron ZEQ25GT mount?
Post by PETER LOO »
Thanks Mooey, but the SkySensor 2000 guide pot pin configuration might not be the same as the standard type, hence, might require to go through a GPUSB-AH type interface for guiding ?
GPUSB-AH is like 80 bucks. It's not a deal-breaker. The SS2K is far, far better than any Starbook. The challenge is that it is old, and if it breaks it would be challenging to repair.
I find the EM-11 way overpriced at 4,300 USD, given that it only has a 25-lb payload. Seems that the best "light" mount would be a Vixen SXD with NexSXD motor board (to get rid of the declination jumps). It is under 20 lb.
That said there are a number of issues now popping up regarding the ZEQ25GT on the CN forum. Personally this turns me off..
orly_andico wrote:That said there are a number of issues now popping up regarding the ZEQ25GT on the CN forum. Personally this turns me off..
Got url?
extremely long thread
http://www.cloudynights.com/ubbthreads/ ... ll/fpart/1
people are reporting things like motors that stall randomly, large amounts of slack in the RA axis, loose motors, etc. etc.
anat
Post by anat »
I just got my ZEQ25 and wrote an "in-depth" review in my local forum:
http://darasart.com/webboard/Question.asp?GID=4268
The mechanical problem can be solved easily. It is still worth it because the ZEQ25 mount is the lightest and least expensive mount capable to do serious astrophotography.
beginner
Post by beginner »
Congratulations.
How about translate so we can benefit from your review.
beginner
Post by beginner »
Anat, what mechanical problem that you are refering to?
You really serious. Strip up to review a brand new eqpt.
anat
Post by anat »
beginner,
It is called an "in-depth" review you won't find elsewhere :)
In short, it is an excellent mount :) Light and capable for astrophotography. There may be some problems (like what orly_andico mentioned) but it can be solved easily. The technical support is one of the best that I have experienced.
Please enjoy photos and videos of my disassembled mount showing how the gear switch and tension screw work. I think it is a good design which leads to the good periodic error.
Clifford60
Post by Clifford60 »
Hi Anat,
Thank you for the in-depth review, you are the man, instead of complaint its weakness, you analyst it with solutions in mind.
Sent from my GT-N7105 using Tapatalk 2
